module and pickup coil plug are green!!!
Old Dec 25, 2000 | 11:29 PM
rondubbs's Avatar
where the module plugs in to the pu coil there is green stuff on the little metal plugs.. could this be the reason my car shuts off after 10 minutes??
Old Dec 25, 2000 | 11:45 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Corrosion there is very common.
Definately a problem that needs to be fixed.
I would probably throw in a new module anyway.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited December 25, 2000).]
Old Dec 26, 2000 | 02:17 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Just had the same problem, wait till you see your pick up coil. A big ball of rust I bet.
87 Z28 305 TPI, Auto, 2.77, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47.
Old Dec 26, 2000 | 08:19 PM
rondubbs's Avatar
what does the pickup coil look like?? is it under the rotor?? is that it,, whats a reluctor?
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
Winchester1094
Aug 18, 2015 10:23 AM
