GM FI Coil ?'s (need help quickly)
Old Nov 22, 2003 | 12:40 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
I am in the process of a TPI swap and I need to know what all the wires that go to the coil do and where to hook them up.
My setup has the Black connecter that hooks to the distributor.
I just picked up the grey half of the connector from a junk yard. It has 2 wires on it and I need to know where they go.
Pink/black & Black/white.
What do these wires?
What do the wires in the black connector do? (there are 2 wire, pink & white) thanks alot.
I am at a dead sprint trying to get my TPI hooked up and running before elk season (Thursday) so I need this info quickly. Thanks
Old Nov 22, 2003 | 01:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: GM FI Coil ?'s (need help quickly)
Small cap distibutor & divorced coil? If so then the 2 pin connector on the distributor goes to the coil. Sounds like you have the coil half. It is just a short wire pair with a connector on each end. Can also get them from a myrid of cars & trucks (vans) with the same coil/distributor setup.
RBob.
Old Nov 22, 2003 | 05:27 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Yes, small cap divorced coil. I have the small wire connector from the coil to the distributor.
I need to know what the other half of the connector that goes to the coil connects to.
The black half of the connector is coil to distributor, but the grey half is ...
The pink/black and the black/white wires are what I need to know about. What do they connect to? Thanks
Harley
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
3.8TransAM
Sep 27, 2015 08:37 PM
