*WHAT* is in this car?!??
Ever since I bought this T/A last year, I have been wondering as to what camshaft is in the bloody thing. Supposedly, it had been rebuilt & the block had been freshly repainted, so well that the block HAD to have been out, and a camshaft was supposedly added. There is a part # sticker on the old stock air element I have, that goes as such:
Competition Cams
Part #: 12-207-2, 12-208-2, 12-206-2
12-314-4, 12-310-4, 12-312-3,12-402-4
12-106-3, 12-400-4, 12-210-2
Carb exec order: D-279-6
So it could be any one of these 10 grinds, or what? I would assume the carb exec order means it's c.a.r.b. approved. The car pulls well (for a 305) to 5,500RPM or so (ever since the performer intake & tes headers went on), but the 3.73's could pull anything past peak horse rpm, so...
Now I have these torquer 305 heads to go on (possibly), and a smoking 350 on a stand in the driveway. I figure slap on the heads and drive it into the dirt. =) But if this cam is new, and agressive enough (for 300-325 horse) maybe I can slide it into my 350. Otherwise, I'll be saving for that XE268 package.
Thanks,
Hype 1983 Pontiac TransAm.
Competition Cams
Thanks,
Go here, think this should help:
http://www.compcams.com/speccard/12-211-2.txt
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
bsa
That is a multi-item decal. That CARB EO number on the bottom applies to all the part numbers listed above, one of which (no way to tell which one) you presumably have.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
AOL IM: Andy89RS
I missed a little something when I first looked at their spec sheets. I didn't notice the different part number beside each one, DOH. Don't I feel smart. You would be best off calling Comp and asking the what the **** is up.
bsa
bsa
Car: 4
Engine: 6
Transmission: 5
It could be any of those grinds. The only way to know with any degree of certainty is to get a degree wheel and a dial indicator and measure it. Those are all relatively mild cams obviously, as they would have to be to have a CARB #, they range from a dupe of the old 151 cam (yuck) to some 260s, 262s and 265s. Some of them are performance oriented and some are RV/towing and some are near stock replacement.
