Rebuilding a small block 350??
Old Nov 23, 2003 | 05:16 PM
White95's Avatar
Car: '95 3.4L Camaro
Engine: 3.4L
What are the best part combos to get the most HP out of a small block 350?? I'm certainly in the planning stages of building a 350. I plan on having a blower, carb.(s), and nitrous. What parts are the best for my plan????
Old Nov 23, 2003 | 05:51 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
You seem to be new to this subject. I highly suggest you pick up the book 'How to Build Max Performance Chevy Small Blocks' by David Vizard. This will set you in the right direction. Mr. Vizard really knows the SBC and what works and what doesn't work. All of his books are really informative.
Old Nov 23, 2003 | 05:56 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
The first thing to do is decide how much power you want to make and where at in the rpm range. Then decide how much you want to spend on the engine and go from there...
Old Nov 24, 2003 | 05:42 AM
ede's Avatar
ede
and figure out what application you intend to apply the engine to, like drag racing ,dirt track, auto cross. might want to consider finishing school and gettign a very good paying job too so you'll have the jack to support the car and engine.
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
