help me with MSD install!
Old Dec 28, 2000 | 12:58 PM
DeathMobile's Avatar
i'm hooking up an msd 6al and an msd btm
how do i hook up the coil wires and the magnetic pickup wire or the timing wire?
Al I have to work from is the diagram on the bottom of the 6AL, and it shows things very simplified for a carb setup.
Also, where is there a boost source on the manifold or engine??? To hook up the btm and the boost gauge, it says i should hook into a pressure source on the manifold or engine.
DeathMobile, aka TheWraith
[This message has been edited by DeathMobile (edited December 28, 2000).]
Old Dec 28, 2000 | 05:41 PM
z/28cwby's Avatar
Goto msdignition.com and you can download a set of instructions that have diagrams for vacuum and electronic advance distributors, and 5 or 7 pin modules.
1984 Z/28
GoodWrench 350, Edlebrock Performer intake, MSD 6AL Super HEI kit, Crane CompuCam 2040, Edelbrock headers, Catco cat, Flowmaster aftercat, K&N, Custom 700R4, B&M Megashifter, Eibach springs, Energy Suspension Hyperflex kit, KYB GR-2 struts/shocks, Jegster adj LCA's, Lakewood adj panhard bar, BFG Comp T/A's, 180* stat, AutoMeter Pro-Comp COOLANT GUAGE.
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
