Fuel Pump?
Guest
Posts: n/a
Fuel Pump?
My 1989 350 TPI IROC has trouble starting sometimes. Every few months, out of nowhere, I will get in my car, start it and drive to a store for example. Then when I come out from the store 5 minutes later, I will get in the car, put the key in and it wont start. It will crank just fine for as long as I want until the battery dies. It just won't fire. This has happened several times. The only way I have been able to "fix" it is by letting it sit for a few hours and try again later and it works fine.
Why does it do this?
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
1989 IROC-Z
350c.i. TPI
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
K&N Air Filters
new:
http://go.to/iroc-z
89,
It is possible that the fuel pump is a problem, but your description of the symptoms sounds more like injector leak down.
The method to determine either cause is to attach a fuel pressure gauge to the Schrader valve on the right fuel rail and monitor pressure. Warm your engine normally or wait until you return home from a drive, then connect the gauge. Try starting after five minutes of whatever period you feel is "right" and monitor the fuel pressure. If you have at least 37 PSIG, the pump is O.K. Shut off the engine and watch the pressure. If the pressure drops within 10-15 minutes, the injectors are probably leaking down. The extra fuel is flooding the chambers and preventing a good start. Waiting a few hours allows enough time for the fuel to evaporate and dry the plugs enough to fire.
When you get the no-start condition, you can try to hold the throttle open a bit while cranking to help admit more air. This is a band-aid, and you'll eventually need to service the injectors. If the engine starts in this manner, you'll probably see a little black smoke on startup, confirming the rich condition.
If that is the case, and since you've installed an AFPR, you already know how to get the fuel rails off the engine. Remove the injectors and ship them off for repair/cleaning/flow matching. You should check out Cruzin' Performance if you need injector service.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited January 01, 2001).]
Later,
Vader
Car: Take
Engine: Your
Transmission: Pick
Read this, it may be what you are talking about :
https://www.thirdgen.org/messgboard/...ML/000526.html
P.S. skip past John and I shooting the breeze, there is some good info in there.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited January 01, 2001).]
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
ok, this is the same problem i am having, except soemtimes it will start and run rough. one time when it was doing this i took out #1 plug and it was wet. i dont know if it was just coincedence, but i dried the plug off put it back in and it started. ign. module???????
beau-t-ful yellow 85 iroc
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
