NOW THAT I HAVE YOUR ATTENTION
I am very interested in the Comp Cams 274: it has 230/236 duration and .487/.490 lift. I am wondering if you think it's TOO BIG for my heads(cast iron L98)? CHP did a test with L98 heads that used a 268 cam it features 224/230 duration. The cam worked wonderfully loosing no low end. I am not afraid of losing a few lbs of torque below 3000rpm just not a ton. My car is relatively light weighing only 3465 w/driver, and geared very well. A list of the mods impacting on the cam are listed below. Thanks. - JDMZ28
89' vette 350 block, 9.3:1, Holley 650 DP, Weiand action plus intake (0-6000rpm), cast iron center bolt heads, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, T5 with 3.35 1st gear, 3.73 posi, ET 13.22@ 106.4MPH
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
JDM,
I think that has a 110° LSA and corresponding longer duration. As long as you're using a manual trans and don't mind a little choppy idle, the cam should be O.K. for street use.
Like I always say, you can't trust anyone else to pick your cam for you, since you'll have to live with it. This one is fairly mild, and could probably be used with a stock automatic and converterwith the 3.73 rear end.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
OW DAMMIT! You got me all excited and I came in here and found out that you just had a problem with your car. Don't play with my emotions like that, LOL.
'86 IROC-Z, 305 LG-4, T-5, T-Tops, 50k Original Miles, K&N Air Filter, Jet chip, KYB Shocks/Struts, Centerforce Dual Friction, B&M Ripper Shifter
[This message has been edited by SGT SWEETPANTS (edited January 01, 2001).]
