4-bolt question
Old Dec 7, 2003 | 10:05 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
4-bolt question
I am assembling my engine tommorrow and cant find any info on the main caps other than 65 ft-lbs-----my question is do you tighten the inner ones first then outter or vice versa?Or is there any other mystery to them i dont know about. I am aware that you start with the center cap and work your fwd and aft. also I usually torque them in 3 steps to the final torque. just curious which bolts to tighten first
Old Dec 8, 2003 | 12:08 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Start in the center and work your way back and fourth. Make sure to use a 30w oil on the main bolts when you assemble, so your bolts dont bind in the threads and give inaccurate tq readings. Dress all the bolts you plan to tq with 30w oil and check them again after 15 minutes.
Old Dec 8, 2003 | 05:53 AM
ede's Avatar
ede
i use moly lube instead of oil, but it's all about the same. i use 3 steps when i torque the main caps and recheck after a few minutes.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
