Removal of TES headers, need HELP!
I made the honest mistake of not JET coating my Edelbrock TES headers before I installed them. Now... I want to JET coat them after they are already installed to my edlebrock 6085 aluminum heads. My question is.... Can I remove them while the rest of the engine is still intact? Has anyone done it without screwuing everything else up. I am removing the valve covers to put new chrome ones on, so they will be out of the way, but can it be done????
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
Yes
Removal of bolts from aluminum heads should be done slowly and carefully. Some Liquid Wrench or WD-40 a day or so before on the bolts is good insurance.
Oh the dipstick will have to be unbolted and removed. Remove the spark plugs and fan sensor(if equipped) to prevent breakage. Note on some cars the A/C compressor and steering rag joint need removal or movement. Good Luck
hectre13
Sep 8, 2015 03:38 PM
