fuel injected 355's, how fast is yours?
Old Jan 2, 2001 | 07:33 PM
88IROCARMY's Avatar
Okay I have a 92 350 long block.
I have looked at the 383 combo, but for the smallest budget seems that a 355 will do.
Containing AFR 190/195 heads, ZZ-9 cam Superam and aboaut 10:1 compression.
My question is what success have you guys had with your streetable 355 i.e. HP,ET's and comments
Old Jan 2, 2001 | 08:40 PM
irocbsa's Avatar
My motor dynoed at 336 RWHP and I am running low 13s. Mods are in sig.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Jan 2, 2001 | 10:11 PM
bad camaro RS's Avatar
13.3@106.66 best average 13.5 104.66 mods in sig jus got my afr 195cc hopeing for 12's
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Old Jan 3, 2001 | 04:12 PM
David 91RS/Z28's Avatar
Still breaking in the motor, but I am hoping for at least 380rwhp and 400+tq. I hope to get some dyno and 1/4 times in a month or two. Still tuning on my computer for driveability now and will tune WOT later. You can see all the mods on my website. I can tell you it feels freaking awesome though. I can easily blow my Nitto's away rolling in 2nd gear.
David Tuschhoff
1991 RS Camaro M5
A SuperRammed, TPIS,
Ross, AFR, Scat, Crane,
CompCams induced 355!
My f-body page!
Old Jan 3, 2001 | 09:03 PM
88IROCARMY's Avatar
Okay I guess part 2 of my question.
How much do you have invested in your 355 long block.
David your engine seems like the combo that I want to start.
I'm using 12's as a benchmark, I'm actually an autocrosser/road racer. drag racing breaks to many parts. (What's New!)
Old Jan 4, 2001 | 01:59 PM
I probably have about $4500 in the engine alone. This includes all the parts and machine work. No labor as I've done all the work myself.
David Tuschhoff
1991 RS Camaro M5
My f-body page!
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
