valve job
Old Dec 9, 2003 | 09:23 PM
eddie jr's Avatar
valve job
just curious......I always thought a valve job was getting the valve seats and head precision ground at a machine shop so they mate nicely so as to not lose compression.
However, recently someone was telling me you can use lapping compound, put it on the valve seats and then (after removing the springs etc) turn the valve (in its place in the head) with an electric drill. Has anyone ever heard of this. Will this actually do an effective job???
thoughts, comments????
Old Dec 9, 2003 | 09:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes you can lap the valves if they are in good shape along with the seats. Infact you are supposed to lap the valves before you install the heads anyway to insure good valve seal.
Old Dec 10, 2003 | 08:11 AM
ede's Avatar
ede
lapping is more of a finishing operation, it doesn't replace valve grinding
Old Dec 10, 2003 | 10:40 AM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
A good vavle job should consist of a few things. working at a machine shop, I do this crap daily.
First- The heads should be degreased and magnafluxed. Heads from F-bodys are cracked more often then yor average car head since they get beat.
The valves should be checked for stem wear and replace as neccasary. The valves should be ground- only if there is enough vlavle left to grind
The guides should be knurled, or replaced if neccesary. Again heads from a sports car are more prone to wear in this area.
The springs should be tested, and are ussually weak from high rpm.
the seats should be ground, and replaced if sunk, or chewed up
the locks/retainers need to be evalulated. Locks take a fair beating.
The head should be surfaced as well.
the springs should be shimmed back to the correct installed height on a SBC 1.700 inches.
Lapping the valves is a process I don't reccomend. Its only good for a finish.
If your valves are not sealing or your burning oil YOu need to consult a professional. Joe
Old Dec 10, 2003 | 06:43 PM
eddie jr's Avatar
so I am assuming then that if the cylinders varied in compression (and it was due to valves not sealing perfectly) that this lapping would not really do much of anything and not improve the compressio at all???
Do you mean where the spring sits or where the valve meets the head?
Old Dec 10, 2003 | 07:01 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
always replace the valve guide if worn. no need to knurl them just replace them. if it worn it's worn.
pjsparts
Oct 29, 2025 06:39 PM
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
69GTOby
Apr 18, 2016 02:34 PM
m00n420
Sep 11, 2015 02:39 PM
