Can TPIS's new modified MAF support 400hp?
Old Jan 5, 2001 | 03:42 PM
R.O.B.'s Avatar
On their website, they have pt#300-144, which is a new MAF that has been modified to flow from stock 529cfm to 750cfm. Can this support a 400hp 6000rpm engine?
Rob
'86 TA 305 TPI
Old Jan 5, 2001 | 07:12 PM
R.O.B.'s Avatar
Anyone?
Rob
'86 TA 305 TPI
Old Jan 5, 2001 | 09:19 PM
Damon's Avatar
Can it flow enough air to support 400 HP? Yes. Can the sensor read that much airflow without getting "saturated" to the point it simply doesn't have any range left in it's electrical output to describe airflows beyond a certian point? Better ask TPIS.
Old Jan 5, 2001 | 09:25 PM
Vader's Avatar
And even if the sensor can read that much air mass, the ECM can only interpret the first 255g/S of flow, so the rest doesn't matter. If you can boost the fuel flow in WOT, it would be worthwhile to saturate the ECM input and hang the injectors out for all they're worth. As long as teh ECM sees a near-maximum air mass at WOT, you'll get maximum injector pulse rates to make power.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
evilstuie
Apr 14, 2016 08:52 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
