Help with Gear Ratio
Old Jan 6, 2001 | 11:28 PM
92red'maro's Avatar
I have a 92 Camaro Rs.... does anyone know what the gear ratio is??? Thanx for the help.
Old Jan 6, 2001 | 11:31 PM
Macgyver's Avatar
If it's a V8, chances are it's a 2.73 (Auto) or a 3.08 (Stick).
The V6 cars are nearly all 3.42/3.73 I could be wrong on that though...
Old Jan 7, 2001 | 08:43 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you find your SPID label in your car (has all of your RPO codes in it) post the codes that start with "G" and we can help you if your rear is stock.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
