Heated O2...
Heated O2...
I finally got a heated O2 sensor for my car. Hopefully it will fix my idle problems. I checked the board and everyone suggests using the heated O2 with headers, but I am still confused as to where exactly to hook it up. Are the wires I should be splicing into inside the engine compartment or by the fuse box. What wires should I splice into??? Thanks.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
if i recall correctly the A wire is power, the B wire goes to the ecm or a/f gauge and the c wire is ground, actually i think you can cross A and C. i always weld the O2 bung in the collector when i put headers on, i've saw them in the primaeies before too.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
you'd want something that was hot only when the engine was on. turn on the key and start looking with a tester when you find one turn off the key and if the tester stops working you have a canadate for the power source.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
