What size is the center bolt on the crankshaft pulley?
Old Dec 22, 2003 | 09:40 AM
Luder[PAK9]'s Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 MPFI
I'm trying to bring my car to #1 TDC and my 3/4 rachet keeps slipping and 11/16" is too small. Please don't tell me it's metric--my set stops at 15mm.
Old Dec 22, 2003 | 10:10 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You shouldn't turn it with that bolt anyway. If you snap that bolt or strip the threads, you're the one that's gonna be screwed.
You need to remove the pulley and use a tool like this...
->Click Here<-
Old Dec 22, 2003 | 11:50 AM
ede's Avatar
ede
try a 6 point socket. should be 7/16 fine with a 11/16 or 5/8 head.
evilstuie
Jan 9, 2020 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
LT1Formula
Aug 20, 2015 09:36 PM
blackd-out z28
Aug 15, 2015 08:18 PM
knight72
Aug 10, 2015 09:32 PM
