How much is a typical port/polish????
Old Jan 9, 2001 | 10:24 AM
CamaroX84's Avatar
How much should I expect to pay for a porting and polishing job of my stock cast L98 heads? What about for a reonditioning/3-angle valve job? Also, can I port my own TPI manifold base? How hard is this? If not, how much would that cost to get done? Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
Old Jan 9, 2001 | 06:42 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
The TPI base is not hard, VADER has a Document on this showing/telling all that is needed to do the Plenum and Manifold fairly easy only takes mmm, maybe an hour or two at most depending on what you have at your exposal. Nice gains too, but i have no idea on the heads, sorry.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Jan 9, 2001 | 07:26 PM
CamaroX84's Avatar
Where is that tech article? I can't find it. Thanks.
5.0 Carbed LG4
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Old Jan 9, 2001 | 07:57 PM
Vader's Avatar
X84,
I can't help you with the cost estimate of the head work, since I do most of that kind of thing myself. (I'm a cheap S.O.B.)
The plenum/runner/base porting will take WAY more than an hour. Plan on being tied to your die grinder and templates for at least a good 6-8 hours, including the cleaning and gasket matching of the whole assembly.
The guide is at:
Plenum Porting.pdf
You'll need Adobe Acrobat Reader to open/print the file.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
92camaroJoe
Jul 29, 2023 07:57 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Magman
Sep 12, 2015 11:55 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
92camaroJoe
Aug 13, 2015 06:07 AM
