very quick question on timing
Old Jan 9, 2001 | 08:01 PM
UVA3rdGen's Avatar
if i am past 1TDC by about 60 degrees of the crank, would it be ok to turn the engine backwards or will I be sucking in things i do not want to from the exhuast manifold??
Old Jan 9, 2001 | 08:26 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You'll be fine.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 9, 2001 | 08:27 PM
Vader's Avatar
UVA,
There really shouldn't be anything that harmful in the exhaust manifolds to get in the engine, so it should be O.K.
The bigger problem is that by turning the engine backward from the harmonic balancer center bolt, the bolt might loosen. You should retorque the bolt if that occurs.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 9, 2001 | 08:34 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
You can buy a flywheel tool. This hooks to the teeth of the ring gear and lets you turn the engine from the back so you don't have any problems with the bolt backing out.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
