Code 15, wont rev past 2200, backfires
Old Dec 25, 2003 | 12:24 AM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
I flushed the radiator and replaced all of the hoses today, and now my Z doestn run right. I just finished installing long tube headers yesterday, and it ran well with open headers, I hooked up the exhaust, and now I get a code 12 followed by a code 15,12,15,12... ect. I know that code 12 is normal. The engine idles fine, but as soon as I try to rev it up, once it gets up to like 2000 rpms, it starts ******* and backfiring, and wont rev any higher. It seems like my exhaust was a little rich, how can you tell? Also, do you think I need a heated O2 sensor?
thanks
Old Dec 25, 2003 | 12:50 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Sounds like the symptoms of a clogged catalytic converter...
Old Dec 25, 2003 | 09:46 AM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
cat
I dont have a cat. I cut out all the smog equipment, I have dual exhause that i put on yesterday, so it isnt anything with that
Old Dec 25, 2003 | 11:29 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Code 15, wont rev past 2200, backfires
thanks
A code 15 is CTS (TEMP LO). Check your coolant temp sensor.
Old Dec 27, 2003 | 12:42 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Coolant temp sensor reading really low will indeed give you some truly creative running problems. Prolly just got disconnected while you were under the hood doing other stuff. It resides on the front of the intake manifold, but the thermo housing... I think.....
Old Dec 27, 2003 | 05:25 PM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
ok, I will check that tonight
Old Dec 28, 2003 | 12:48 AM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
cts
Ok, I got the new cts today, swapped it in, and it didnt make a difference. I hooked up the sensor while it was out of the block, and the engine ran the same. however, if I disconnect the cts, the engine dies, and wont start.
I'm still pulling a code 15
BumpaD82
Feb 26, 2016 02:57 PM
Stroopwafel
Sep 11, 2015 06:38 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
