compression....no compression???
Old Dec 25, 2003 | 11:17 PM
themodifier's Avatar
I have a problem with compression on my '91 305 TPI engine. I have good compression on all 8 cylinders with no spark. However, with spark, I lose compression on no. 1 cylinder. I checked the injector, and it's ok. Any idea's?
Old Dec 26, 2003 | 09:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Totally unrelated. What do you mean with and without spark? Compression is completely mechanical.
Old Dec 26, 2003 | 10:31 AM
Typical compression test by disconnecting coil, and turning over the engine results in good compression on all eight cylinders. Reconnecting coil, and starting the engine results in losing compression in no. 1 cylinder. ??????????????
Old Dec 26, 2003 | 10:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
How do you know you're losing compression in cyl 1 if the engine is running?
Spark or no spark will not affect compression numbers.
Old Dec 26, 2003 | 12:31 PM
Vader's Avatar
Please explain. I'm a little confused about your analysis, too. Then again, it often doesn't take a lot to confuse me...
EDIT:
Typical compression testing should be performed by disabling (not just disconnecting) the ignition coil, removing all spark plugs, blocking the throttle plates open, and cranking with a fully charged battery until peak compression pressure is achieved.
Are you talking about a power balance test instead of compression when running the engine?
Old Dec 26, 2003 | 08:51 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
not that i understand your method of testing.... but a bad piston ring would cause that
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
