rear ques.
Traction bars might help. When the wheels spin, the bars lift the rear end of the body up, which in effect pushes the wheels into the ground.
(I'm assuming that's what you're going for.)
89 iroc-z 305 tbi
everything stock, except for a mirror that fell off
89 iroc-z 305 tbi
Transmission: 4L80E/4L80E
If you're talking about winter traction, good tires will be your best investment by far. Then, added weight.
As far as suspension mods like ede and Enkil proposed, they won't help because the traction bars or LCAs are "reacting" to the traction you start with and adding to the force being applied to the tires - on ice, no dice.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
