digital EGR
Old Jan 10, 2001 | 11:33 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
digital EGR
is anyone familiar with the digital EGR valve???? i need to know if it's possible to remove and clean the (3) valves. i can't exactly afford to just buy a new one.....GM price is $350, Pep Boys is around $200.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Jan 10, 2001 | 11:38 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Is it stuck or are you just getting the check engine light.??
If you are getting a code and the valve is occationally sticking you can get a EGR gasket that has a screen accross the intake orofice.
This prevents any voodoo from getting to the valve and causing it to stick.
I have the part # for the 4.3 gasket at the shop, I'll get it tomorrow. I think they use the same gasket.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited January 10, 2001).]
Old Jan 10, 2001 | 11:45 PM
Engine: LH0 3.1L
no codes. all 3 are working properly. i think there is some carbon build -up that is causing one of the valves to remain open a little when i'm decelerating and it starts to choke the engine. (acually stalled it twice a while ago)
oh yeah, if you can get that PN, i can probably order it through work....thanks
Dan
1990 3.1L RS
[This message has been edited by CaliCamaroRS (edited January 10, 2001).]
Old Jan 10, 2001 | 11:49 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Sometimes I get a stall with a customers digital EGR and then it clears itself up.
This is caused by little pieces of carbon passing through the valve.
I usually just spray out the valve (don't try to take it apart) with carb cleaner and use the screened EGR gasket.
This usually clears up the problems.
Its made by Tomco, I'll get it tomorrow.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 11, 2001 | 06:20 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Here is the 4.3 Vortech part #, I don't know if its the same EGR gasket as your 3.1.
2-1357 GM Klean Screen. (Tomco)
Good luck
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 11, 2001 | 11:24 PM
Engine: LH0 3.1L
thanks a lot
sheachopper
Jul 31, 2019 11:27 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Eric-86sc
Sep 28, 2015 11:37 AM
