Can I get the specs on an 83Crossfire 305 engine....
Old Jan 12, 2001 | 01:52 PM
Jason Aschle's Avatar
I have an engine from a 1983 Z28, it is a 305 and had a CrossFire Injection on it with an automatic transmission. What are the specs on this motor, cam,heads, etc. I would appreciate any help. I am putting it into an IROC for a daily driver and am putting a Tuned Port injection on the motor, horsepower is not a big priority with this car, but a little would be nice. Thanks..
1991 Camaro ,polished TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.6 @ 102.5 with a 2:73 open rear, no traction, no tuning, no practice. Car is pictured in Chevy High Performance magazine, June 2000 issue.
1985 California Edition IROC red, polished TPI and polished wheels, otherwise completely stock 305ci. 700r4
1991 fullsize Blazer 4-wheel drive, 350,700r4, Pro Comp lift, K&N, TBI spacer, 3" Catco cat, 3" cat back Flowmaster, etc....
Old Jan 12, 2001 | 06:19 PM
Pat Hall's Avatar
According to my Chilton's manual, it was rated at 165HP@4200 RPM, 240 Ft Lbs@2400 RPM, and 9.5:1 compression ratio. I couldn't find any specs on the cam, but if you're going to be putting a TPI system on it, I'd highly recommend changing your cam to either a stock or aftermarket one for a 305 TPI.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Jake_92RS
Jan 28, 2020 10:37 PM
tom1985
Apr 19, 2016 07:55 AM
ChaseDale3and8
Sep 1, 2015 01:49 PM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
