DAMN WIPERS!
Old Jan 12, 2001 | 05:28 PM
Stuart S's Avatar
DAMN WIPERS!
They don't work...
Motor is good, because if you put current to it it operates fine. I have no current at the connectors for some reason, and the fuse is fine.
I was told that there is a switch in the column but am cluless as to how the column comes apart - if i pull the wheel can i access it? Any help is appreciated. Thanks.
Old Jan 12, 2001 | 07:55 PM
Stuart S's Avatar
anyone?
Old Jan 12, 2001 | 07:58 PM
CamaroMike's Avatar
Stuart the switch is on the turn signal lever. The whole switch assembly can be purchased and replaced but will require some steering column disassembly.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 12, 2001 | 09:15 PM
84FTA's Avatar
Pulling the column apart is dependant on your mechanical abilites. If you are good in mechanics generally or in fine mechanics (small stuff) it's easy. I did a write up on it somewhere on my website (currently down 'cause I'm lazy) but I'll run you through what I remember.
Horn off with screwdriver, remove clip and then nut, pull steering wheel. Use a lockplate remover to take out the snap ring and remove the lockplate assembly. Remove the three screws holding in the turnsignal assembly. I didn't take the wiper swithc off but it should only be a few more screws to remove the arm from the assembly and you'll probably need to remove the hush panel, drop the wires and push the connector and wires back up through the column (they are in a nice holder for the GM line workers).
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-tops
4-bolt main 350, headers, Holley 650, T-5, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Jan 12, 2001 | 09:27 PM
Vader's Avatar
SS,
The column disassembly could be very minor if you have a tilt wheel. The wiper switch is located right inside the little protrusion on the left side of the column. It's a little tricky to install it without removing the steering wheel, but it can be done if you're patient.
This might help:
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
