help removing pressed in rocker stud
Subscribe
Jan 11, 2004 | 07:20 PM
So, I stacked some washers, and used a nut and a breaker bar and began to torque down on it. Tension left and the nut is spinning around, and I can't back off the nut and I can't remove the washers nor the stud. There's still pressure between the washers and the nut. Any ideas how to get this thing off?
Reply 0
Jan 12, 2004 | 04:40 AM
nut cracker, grinder, apply preasure under the nut and spin it. i usually use old rocker or rod nuts and use moly lube and only pull 2 or 3 studs before getting another nut.
Reply 0
Subscribe
