cold air--what do you do with sensors?
Old Jan 17, 2001 | 06:05 PM
squirrelybird's Avatar
Hey guys. I got my K&N and I'm ready to build my cold air. Looks easy...only one question: What did you guys do with the sensors that connect to the old intake? One(at the airbox) is electrical(for emissions??)--the other is a plastic hose connecting the tubing right in front of the throttle body to the valve cover(a breather??). Do I need to connect these to my new cold air or does it really matter? Oh by the way, it's a 91 3.1L bird w/ no MAF if that matters.
Old Jan 17, 2001 | 09:50 PM
Vader's Avatar
Squirrel,
The hose is the crankcase breather tube. This needs to be connected to a source of filtered air, like the base of the filter adapter. The sensor you describe sounds like the IAT sensor. It is used to adjust the fuel mixture and spark curves to compensate for intake air temperature. If you remove the sensor, the MIL lamp should turn on and the ECM will use base lookup tables for fuel and spark calculations.
You really need to install the sensor somewhere in the intake air stream, but it doesn't have to be in any exact location. The farther from the throttle body, the better, since the heat radiated from the TB can cause a leaner mixture and retarded timing due to a false high temperature indication.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 18, 2001 | 03:18 PM
Thanks Vader.
Old Jan 18, 2001 | 04:41 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Putting the MAT in the rubber boot in front of the TB is fine to relocated it, and is where TPIS recommends you put it.
Inspite of my own personal misgivings about the relocated MAT (it causes the engine to run WAY TOO RICH as the GM eprom expects it to be in the plenum), installing the MAT in the rubber boot in front of the TB will give you an accurate intake temperature. I've had mine there for over a year and it reads with 1 degree of the ambient air temperature.
Shouldn't the MAT be in the plenum anyway?
92firebirdguy
Sep 1, 2016 07:53 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
