Dyno 2000
Old Jan 14, 2004 | 12:43 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Dyno 2000
Is anyone using Dyno 2000? I have it, however I don't think it is very accurate. What have you guys done with it. Also if you guys have any airflow or cam files would anyone be willing to let me see them.
Old Jan 14, 2004 | 05:58 AM
ede's Avatar
ede
no one's that used it thinks it very accurate, maybe a good guide, but not accurate.
Old Jan 14, 2004 | 10:00 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
if you want heads/cam files, email me @
n8man1068@yahoo.com
Old Jan 14, 2004 | 01:23 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
#1 rule with DD2000
Ignore the roller cam option. Unless you're running 260* or more duration @.050", it's WAAAAAY to optimistic on the torque.
If you're using a cam that's quite a bit more than stock, you can switch between the solid lifter option and the hyd. option, then average the results from those two.
Other than that, it's OK. Not great, but OK.
If anything, use it more to see what characteristics of the engine change when trying different things.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kammi10
Nov 9, 2015 08:28 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
