Aircon delete
Old Jan 14, 2004 | 04:02 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Aircon delete
Can you guys without aircon post a couple of pics under hood.I am removing mine and need to see what i can remove from the passenger side under hood stuff
cheers
PM
Old Jan 14, 2004 | 04:10 PM
MNformula350's Avatar
Old Jan 14, 2004 | 07:25 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
if your serpentine system is like mine, then i dont think you can remove the AC compressor without some engineering. the belt has to run around the ac so the tensioner will work. i took the whole passenger side accessory bracket off of mine, and found an old alternator mount (for a v belt system) and bolted it to the alt. so i could tension the belt. i wouldnt recommend this if your area has strict emissions laws.
Old Jan 15, 2004 | 01:00 AM
powermite's Avatar
Car: Transam
No its not serpentine and here in the UK the emissions laws arent as tight as yours,so no problems there.
PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
