Dyno 2000 Heads question
Old Jan 15, 2004 | 02:45 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Does anyone know the exact name for our heads or have a heads file for the L69 engine? If not, does anyone know the intake and exhaust valve sizes? Any info would be appretiated
Old Jan 15, 2004 | 02:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are casting # 416, valves are 1.84"/1.5".
Old Jan 15, 2004 | 10:30 PM
I don't have the file and I can not find the file online. Also I want to try to set up my Dyno 2000 file as precise as I can get at stock and to do that I need the airflow file. So when I do changes I will know the correct improvements. Would you be willing to send me the file at ksrammstein@hotmail.com or if you got it off-line where did you get it.
Old Jan 15, 2004 | 11:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If you do a search for that casting number under F-BIRD'88 , I think he posted actual flow numbers.
If his name doesn't work, look under the name Sitting Bull
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86IROC112
Aug 21, 2015 07:20 PM
redmaroz
Aug 16, 2015 11:40 PM
