Dyno2000 numbers
Old Jan 15, 2004 | 07:33 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
Dyno2000 numbers
I was messing around with dyno2000, and came up with these numbers on a 350:
350 Horsepower @5000 RPM
391 ft.lbs @4000 RPM
Thats with World Products SR Torquers (67cc)
9.5 compression
660 cfm carb
dual plane intake
small tube headers with mufflers
and a Powermax 2050 cam
do those numbers seem right?
Old Jan 16, 2004 | 07:54 AM
ede's Avatar
ede
i've never trusted dd200. i'd say it's somewhat close but not accurate.
Old Jan 16, 2004 | 08:02 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Did you put in actual head flow numbers in the "custom port flow"?
Take off the small tube headers and add "HP manifolds" They are way to giving for headers in that program.
I dont know what kind of cam you have but dont use "roller" stick to hydraulic for mild cams no matter what platform. DD2000 is a good guestamate, and is fun to mess around with when there is nothing to do.
Old Jan 16, 2004 | 11:45 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Those numbers sound about right.
Old Jan 16, 2004 | 12:28 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
DD2000 says 500hp for my 383. 1/4 mile results show closer to 465hp.
Old Jan 16, 2004 | 01:47 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That's interesting.
Using the flow numbers from AFR for the 195 Competition heads and all other info you gave, the most HP I got was 479 @ 5500 RPM. That was using the Roller Cam option.
Using the hyd cam option (which is recommended on "mild street" roller cams), I got 468 @ 5500 RPM.
How did you get 500HP?
Old Jan 16, 2004 | 02:22 PM
84 t/a 5.0's Avatar
I downloaded some head and cam files and put them in the custom flow and custom cam section
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
