Lingenfelter 219 Roller Cam Card?
I'm looking for cam card specs for LINGENFELTER'S 219/219-560-560 SBC Roller Cam.
Basically looking for valve spring specs(Installed Height etc)
Thanks.
Thanks.
Car: 4
Engine: 6
Transmission: 5
The cam card won't tell you what your valve spring installed height needs to be. That's a function of the springs, and the lift of the cam they're being used with.
So, what springs do you have?
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I used to have it around here somewhere. You might find it if you search here or at corvetteforum.
I think the spring pressures were 140 closed at 1.90 installed height and 435 open, but I went with a slightly lighter spring, like 135 closed and 350 open and worked fine.
Kenwood
Sep 4, 2015 05:50 PM
