what would cause my HVAC controls to act backwards
Old Jan 18, 2004 | 05:03 PM
matthew's Avatar
I've had this problem for a while. My HVAC controls are acting in reverse order. Like when i go to def. the car acts like it's in the off position, and when I go to heat or vent it acts like its in the AC spots. The air comes out in the right vents, but the compressor kicks on in the heat and vent positions and not in the def. or AC positions. I thought maybe the wire was hooked on backwards in the back of the control box, but I looked and I didn't see any way that it could be hooked up wrong. This isn't a really major problem, but its still really annoying to drive around with my compressor on when I don't need to. What do you guys think could be the problem. And on a relelated note, my fan doesn't work in the defrost position either, but it works in the vent and heat positions. I don't know if these problems are related, cause the fan problem just started recently.
Any help you guys could give me would be greatly appreciated.
Old Jan 18, 2004 | 07:06 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
There are very small vacuum lines running underneath the dash that are all rigged up to the HVAC controls. I would assume someone took the dash off at some point in time and put the lines back incorrectly, which would swap the HVAC controls all around.
Old Jan 18, 2004 | 08:30 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
On the TGO main page, go to Tech Articles and to the Electrical section. You will find a link to 1986 wiring diagrams. Follow the link to the page that pops up and scroll down to the Air Conditioning section, and click on Vacuum Control. That is what you are looking for. As for the compressor operating when the heat is on, you have a wiring problem that should not be there. And as for the fan, are you talking about the main engine fan? That definitely sounds like a wiring problem.
Old Jan 21, 2004 | 11:50 AM
matthew's Avatar
I don't know if it is a vaccum problem. Cause the air comes out the right vents. Like when I have it switched to def. it comes out by the windshield, and when I switch it too vent, it comes out the vents in front. So I think its a wiring problem causing the compressor to kick on in the opposite positions. But I'll check the vaccum lines anyways.
Old Jan 21, 2004 | 03:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That section also contains all of the related wiring diagrams you need.
Old Jan 22, 2004 | 06:34 PM
matthew's Avatar
thanks for your help guys, I'll try with those wiring diagrams and see if I can see whats up. Also, its the blower fan that doesn't work on defrost, not the engine cooling fan, sorry for the mixup.
Chevykid810
Sep 28, 2015 12:57 PM
RedLeader289
Sep 23, 2015 06:50 AM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
