crank pulley bolt pattern... diff between SBC and LT1???
Old Jan 21, 2004 | 09:59 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
is the bolt pattern for the crank pulley the same between a LT1 and a SBC?
im considering using a blower pulley ment for a LT1 to run my blower on my SBC.... i need to know if they will bolt together though...
Old Jan 21, 2004 | 10:24 PM
Vader's Avatar
An LT1 balancer is actually two pieces -a hub, and a balancer ring assembly that bolts to the hub.
I doubt that the blower drive will bolt directly to an older balancer.
Old Jan 22, 2004 | 08:24 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
darn.... and i thought i found a solution too.
mmk, thanks vader.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
MoJoe
Sep 15, 2015 12:50 AM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
