T-top question - lexan vs. glass & interchangibility...
I've got the lexan t-tops on my '92 RS and was wondering how hard it would be and would it be worth it to swap them out for glass t-tops. One of my t-tops is slightly scratched on the outside, the metal trim has surface rust, plus both of them have the internal cracking that I hear they are notorious for. If I found some glass t-tops, I should be able to just swap over all of the hardware (locks, drip rail, trim cover, etc) to them, shouldn't I? Any advantages/disadvantages with the glass t-tops? I don't really care that they are heavier than the lexas tops, unless of course the weight causes some sort of other problem.
I know a guy who has a set of glass ones for sale with the leather storage bag for a good price. I think they're off an 88 IROC. His name is Shawn and his email addy is smiller@bmt.net. Or you can call him at (406) 683-4160.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I swapped my glass ones for some lexan ones from a formula. I swapped all the hardware also since locks worked and he didn't have the keys for his.
All the third gen t-tops should be interchangable size wise.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I actually did this swap tonight. Everything fits fine, if it doesn't just adjust the plastic "brackets" on the pillars. I now have less wind noise and less squeeks
- 89 Formula 305 WS6
SFC's,
LCA's,
Air foil
Flowmaster cat back
Tranny Cooler - 90 Eagle Talon 2.0
(winter beater)
Street Lethal
Apr 30, 2019 12:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
