a/c delete
Old Jan 24, 2004 | 03:06 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
a/c delete
i have taken off the whole a/c system and replaced the heater box in the engine bay with one from a non a/c car. My heater controls seem odd. When i put the slider on vent, the air still comes out at the top of the dash where the defrost air comes out. The only way i can get the heat to come out the vents is to put the slider on the a/c side on max or normal setting. Is that a problem or is it normal because i removed the old a/c system?
Old Jan 24, 2004 | 03:18 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
sounds like a vacum problem I removed my A/C and did the same thing but my controls still work to blow air out the correct vents.
Old Jan 24, 2004 | 03:19 PM
2 dope's Avatar
Engine: 305 LG4
ya im starting to believe that the vacuum lines are messed, my carb is acting crazy as well.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
