Question of cubic inches...
Old Jan 27, 2004 | 09:01 PM
BadBowtie88's Avatar
Here's the deal, I have my 350 already bored and ready to go on the engine stand. I need heads, cam, and engine kit and she'd be back on the road. However, I have a virgin bore 400sb sitting in the floor untouched. My HSR would bolt right up to it. But, the catch is, it has no crank, rods, etc. Now, would it be worth it to go ahead and spend the money to buy all the hardware for the 400 and bore it, then drop it in my '89 Iroc? Or should I just go ahead and finish the 355? Any comments will be appreciated. Thanks in advance.
Old Jan 27, 2004 | 09:17 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I assume that you do have a crank & rods for the 350 shortblock...
If so, buy the bearing spacers that allow you to put a 350 crank in your 400 block, fit 400 flat-top pistons on the 350 rods and you have a 377ci. They work very well.
Old Jan 27, 2004 | 09:26 PM
Of course I have all the components for the 350, it is the motor that came out of the car originally. I would do the 377, but it just seems like a waste of a good 400 block to me...just not a big fan of them.
Old Jan 27, 2004 | 10:20 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
It seems like it would be a good idea to price out a few kits and then ask yourself if it's worth it. There are cheap kits and expensive ones.
To some guys it's worth it to spend $800 on a set of shaft mounted rocker arms.
If it were me I'd finish off the 350, then start on the 400.
Or maybe I'd build a 377.
Old Jan 28, 2004 | 07:20 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
I'd do the 400 now and save the 350 for a future project. Other than the 350 is machined the cubic inches in the 406 are cheap when doing a rebuild.
Old Jan 28, 2004 | 09:21 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
There's no replacement for displacement.....if you can afford it!!!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
