stock lt1 compression? 1996
Old Feb 2, 2004 | 04:55 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
what is the stock compression on the 96 LT1 w/Al Heads from a TA?
Old Feb 2, 2004 | 08:43 PM
Vader's Avatar
Static compression ratio is 10.4:1.
Old Feb 2, 2004 | 10:09 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
thanks
Old Feb 2, 2004 | 10:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Are you sure, I thought it was 10.5:1. Not like this is a huge difference but everything I know about LT1's says that.
Old Feb 3, 2004 | 05:57 AM
Vader's Avatar
The blueprinted static compression ratio should be 10.44:1. You can round that off any way you want, I suppose. It's not a lot different than the LS1 engines being called "5.7L", while the actual displacement is only 345.6 CI, or 5.66L, and a "350" is only 349.8 CI, or a "396" is actually 402 CI.....
The LT4 engines had a static CR of 10.8:1.
Old Feb 3, 2004 | 07:23 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea that makes sense. I did know that about the Lt4 though. I geuss GM has a habit of rounding up. I geuss most literature just keeps it simple.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Thirim
Aug 9, 2015 06:19 PM
