Speed limiter @ 105, or incorrect speedo?
Old Jan 29, 2001 | 02:02 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
OK, so which is it. My 92 Z28 vert ran into the speed limiter at an indicated 105. I thought it was supposed to be 118? Did verts recieve an even lower speed limiter?
just curious, it'll be the first thing gone when i start burning proms anyway...
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jan 29, 2001 | 04:47 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Yea, my vert had the speed limiter at 105 too. I got a Hypertech chip hoping it would get rid of the limiter, nope. Then I got a Jet stage 2 chip and it moved my speed limiter to 130 MPH. Thats when I had my ol 305 and was mostly stock.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
GTAman
Jul 3, 2024 07:29 PM
Stangski09
Nov 14, 2015 01:27 PM
TrevinE
Sep 14, 2015 03:20 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
