New Block
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
New Block
I have a L69 motor and I wanted to change it out with a 350. Now instead of paying for a cheap crate engine or something like that and just change all the parts. Is it okay to go to a junk yard pick up an engine cheap and strip it. Then send the block to get magnafluxed and reworked then use that as a starting point instead of paying for parts you don't want?????
I am sure someone here has does this....
What do you guys think?
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
ksrammstein, i'm selling a 350 engine block for 100 bucks. It's a virgin bore 4 bolt main. It's pre 87 though. Thought i'd let you know since i'm pretty close to you.
skinny z
Oct 5, 2015 06:23 PM
