Difference between these...
Old Feb 3, 2004 | 06:44 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
gasket kits?
FEL-KS2656 for 87+
FEL-KS2644 for 81-85
the ones for the roller are $30 more than the ones for the flat tappet...
is there a difference that I can't work around? I'd like to save $30 if possible.
for a 92 firebird
Old Feb 3, 2004 | 08:31 PM
Vader's Avatar
If that's a rebuild set, the KS2656 will have the correct rear main seal, correct valve seals, and a few other differences I'm probably overlooking.
Old Feb 3, 2004 | 08:33 PM
Vader's Avatar
Oh, yeah. Center bolt rocker covers, intake flange gaskets with the correct hole positions, and timing cover gaskets also come to mind.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
