O2 Sensor Woes...
Old Feb 3, 2004 | 10:02 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
O2 Sensor Woes...
Start car... O2 sensor warms up and works fine.
Roughly 20-40 minutes pass, O2 sensor suddenly drops to .18-.20 volts and stays there. causes computer to push a bunch of extra fuel in.. of course.. but O2 sensor stays lean the whole time.
Shut car off, walk away for 30-40 minutes... come back..
O2 sensor works again.
Its a 3-wire, heated, been working fine for 6,000 miles... till now.
Old Feb 4, 2004 | 08:45 AM
Vader's Avatar
Just a WAG, but is there possibly a connector that is routed close to the exhaust or something else that may be heating it?
Old Feb 4, 2004 | 10:38 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Is this the same O2 that was acting up like two months ago, or is this a new one?
Old Feb 7, 2004 | 06:48 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
A new one. the old one was doing other weird crap, like shutting itself off for no reason.
This one also never goes past .75 volts. usually they swing from 0V to 1.0V but this one only swings to .75 if its REALLY rich then back to 0V. It seems a random thing when it dies off too...
i have a valve cover leaking oil down the back of the motor. the connector gets soaked with oil occasionally... i wonder if that might be screwing it up?
Old Feb 7, 2004 | 10:33 PM
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
The oil leak can do it. O2 sensors need outside air to function properly. It compares the outside air to the exhaust to tell how lean/rich the mixture is (ie how much voltage to send to the computer). If the oil runs down the wires into the sensor, it will block of the supply of fresh air. If this is the case, the sensor might need to be replaced again. To be sure, stop the oil leak and see what happens.
Old Feb 7, 2004 | 10:54 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
i would be suspicious of a wiring problem. ive had a wire going to a sensor that intermittently started acting up only when the engine is hot. tough to track them down sometimes but what i did was hookup the scanner and have someone giggle the wires at various engine temps till i found the frayed spot in the wiring, then replaced the bad wire.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
