electric fuel pump
Old Feb 5, 2004 | 08:31 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
electric fuel pump
I'm doing a 350 swap in my 91 rs. The car was tbi and now its going to be carbed. I bought a mallory 110 comp electric fuel pump. Can someone tell me how I need to install it?
Old Feb 5, 2004 | 08:54 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
have you though about using your TBI in-tank fuel pump n regulate it?
If you dont like that, run a 12 volt power off the ignition to the pump (so it engages when you turn the key on, you can tap into the fuse panel or use your power feed that went to your TBI pump, I think you can find it underneath your carpet by your seat.) and run a ground.
feed that to your carb, your set. with most electric pumps like that you wont need to use the return line.
Old Feb 6, 2004 | 07:47 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
[ Read the post wrong sorry
Old Feb 6, 2004 | 02:13 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
Thanks a lot. You answered my question perfectly.
Old Feb 6, 2004 | 11:46 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Dont forget to use the oil pressure switch if you keep the stock wiring.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
