how much knock is acceptable
Old Feb 7, 2004 | 11:34 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
i think i've got my timing set pretty close to optimal performance-wise, but i do get a few knock counts showing up on the laptop at w.o.t.. i've heard that's normal. i can hear no pinging and any less timing has a negative impact on performance. my question is, what is an acceptable # of knock counts for a w.o.t. run? mine are usually in the 20-40 range. anybody know?
Old Feb 8, 2004 | 12:19 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I'd try for none, if possible.
Try retarding the timing another degree or two and see what happens.
Old Feb 8, 2004 | 10:51 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: how much knock is acceptable
Yes that is very normal. Unhook the sensor and see if performance increases again. A small rattle here and there at WOT is not the end of the world. If you can't hear it with your ears and it does not hurt power output then you're good.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
gord327
Oct 3, 2015 01:25 PM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
