Please Help!
Old Feb 15, 2004 | 11:54 AM
freestylin's Avatar
Please Help!
hey i have a 87 v6 2.8l firebird and my engine is making a weird tapping/knocking noise when i start it and gets louder when i push on the gas does anyone know what this is?
Old Feb 15, 2004 | 12:07 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Possibly a number of things.
It could be broken distributor components, a faulty emission system or a vacuum leak. Also check your ignition timing, carb adjustment and make sure you have the proper spark plugs for your engine and have correctly gapped them. Make sure there is no damage to the wiring, either.
Old Feb 16, 2004 | 04:36 AM
Vader's Avatar
Checked your oil level? Do you have oil pressure? Does the sound vary in frequncy with engine RPM?
