crankshafts?
Old Feb 15, 2004 | 09:55 PM
pskel350's Avatar
crankshafts?
is it possible to fit a 3.875" stroke crank into a 350 block?
or maybe the better question is will it be safe and not weaken the block much?
the shop told me that they can do it, and it would be ok. but i want some more opinions and actual experiences from more people before i start buying the rotating assembly
Old Feb 15, 2004 | 10:49 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Should be fine. Have them partially fill the bottom of your water jackets.
Old Feb 16, 2004 | 04:48 AM
ede's Avatar
ede
4" is about the upper limit, but there are so many variables and it depends too on what you want to do or not do to the block, rods, cam to make it work.
Old Feb 16, 2004 | 07:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it is possible.
I doubt they would be so readily available from so many sources if it was not possible.
That stroke in a .030" over 4" block is what people commonly call a 396 small block.
Old Feb 16, 2004 | 08:43 PM
pskel350's Avatar
i just didnt know if everyone building 396 small blocks were using aftermarket blocks or not
thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
LT1Formula
Aug 20, 2015 09:36 PM
