car misfires w/ black plugs. too rich?
Old Mar 6, 2004 | 11:15 AM
  #51
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
ok...i still have a slight hesitation at WOT and high rpm's...im thinking it's either my small air cleaner (the lid of the cleaner gets sucked down when i apply throttle) and my cat is probably really clogged from running rich for so long.
or could it be my secondaries kicking in, and the jets are still too big?
also, my fuel pressure is at like 5psi. would 7psi help?
Old Mar 8, 2004 | 07:33 AM
  #52
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Try driving it without the air cleaner. Just for testing!
You also need to go make a 1/4 mile pass on a safe road. Then pull over and check your plugs. You may be too lean with those jets. I could be wrong, but you should check your plugs.
Your fuel pressure should be ok at 5 psi
Old Mar 8, 2004 | 09:17 AM
  #53
Wezzeles's Avatar
Car: Camaro
check your vacuum plugs, when i had one off, it ran like that
Old Mar 8, 2004 | 12:58 PM
  #54
Engine: carbed L98
i have 64 primaries and 72 secondaries. ill check my plugs if i can find a long street around here...thanks.
Linson
Oct 24, 2025 02:00 PM
mrbird
Oct 20, 2015 03:43 AM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
indygene
Sep 26, 2015 11:21 AM
