accel 24lb injectors
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
Hi, i,m new to this site. this is my first time asking a question here.
my question is, should performance injectors be the exact same
length as the stock ones? the accel injectors i bought for my 87 z28 are about a quarter of an inch shorter than the stock ones.
is this a promblem or not?
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You might want to try the Tech/General Engine board. This board is for problems, help, suggestions, and comments having to do with these message boards.
Welcome to thirdgen.org, by the way.
they still should fine, lots of people use them with no problems. try doing some searching https://www.thirdgen.org/techbb2/search.php
u can see people's comment and other info on most things.
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
