Ahh good times....
Old Feb 19, 2004 | 01:07 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Ahh good times....
I was under the car yesterday and decided to check on the condition of my cap/rotor. PO said he replaced not long ago. Spark plug wires new as well. So I take off the cap and whoa...it sure is messy under there.. It looks like he had tightened the cap down too tight so that the rotor had actually started to melt away into the cap. Interesting. I take the cap and rotor off for closer look and it looks like the cap wasn't centered over the rotor either. So there is a little groove worn into the cap that is not centered over the little carbon button in the middle of the cap. And the burn marks electrodes on the inside of the cap are all along the bottom of the electrode where it is molded into the plastic. So, i cleaned it up and will now see if it makes any difference. Damn PO!!! Is there anything I can spray on the distributor (under the cap area) to clean all the dirt and crap away with? One more thing...I checked to see if there were any sparks with car running in the dark. I saw sparks at all cylinders. Very small and faint right at where the wire clips into the plug. Is that ok?
Old Feb 19, 2004 | 01:39 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Irregardless of what the "PO" says, I would replace the cap, rotor & wires with the correct AC Delco (or NAPA/Eclin) replacement parts.
Old Feb 19, 2004 | 02:35 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yes, And dont just start "pullin wires "replace them one at a time...
Old Feb 19, 2004 | 06:42 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Without ever doing it, I would suggest a non-conductive electronic cleaner spray for the distributor. The stuff should do the job and not harm anything.
Old Feb 19, 2004 | 07:47 PM
Engine: 406
Or wd-40...best to just buy new...cheap enough.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
