Dynomax Race Bullet
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What do you need to know? They're basically a resonator, ie. glasspack, type muffler with a straight flowthrough. They wouldn't lower the decibles down enough for street use but will quiet a race engine down without restricting exhaust flow.
Think of it this way. If you think you can get away with a muffled exhaust like "thrush" or "cherry bombs" then the Bullets would work. If you think it's too loud and you'd get a ticket then they won't work. A loud exhaust like that sounds nice for a while but in a daily driver it gets annoying after a while. I have some good dynomax mufflers on my truck and cruising down the highway at 3000 rpm, I need to crank the stereo up to hear it and the windows are closed. Around town it's not bad but it's also not as loud as a straight flow through muffler.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited February 05, 2001).]
Best 60 foot: 1.662
I had one where normally the cat would be and that's where my exhaust ended. It exited right under the passenger side. I had a 350 bored .60 over with 10.3 to 1 comp. It sounded nice, but like Stephen said, it is kinda Loud !!
Don't think it'll be legal in the States...!
how did it sound? my muffler rusted off 2 years ago. i had it like that for a couple of months. i liked the volume but it kind of sounded like crap. will the bullet give me a deep tone? how does it sound?
im probably going to put it where the stock muffler is and have a straight pipe where the cat should go.
what if i put 2 on? would that make it sound deeper? thnx.
[This message has been edited by 305-Jive (edited February 06, 2001).]
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
I have had these on many different engines. They are very loud like others stated. They have a rather harsh sound which is either racy or sounds like crap depending on who listens. While they don't have that deep (like flowmaster?) sound, I think they are great for the money, size, and weight. They quited down my straight piped 327 nicely.
sorry for the late reply...
I wouldn't know about having 2, that was my original intention. To place one under the driver for the 1, 3, 5, 7 cyl. and the one beneath the passenger for the other headers. but I could not get anything beneath the driver side.
Maybe your just thinking about putting 2 in a row, that might work too...
I really liked mine and it sounded deep enough for me !
Think about it though it's not legal...!
darwinprice
17
Oct 11, 2015 11:51 PM
tmork454
Sep 29, 2015 06:33 PM
