crate motor for 93 caprice 9c1 specs?
Old Feb 23, 2004 | 09:50 AM
93lo5inaburb's Avatar
Car: 88 suburban 4wd
Engine: crate l05 for 93 caprice 9c1
I recently had to have a new motor put in my 88 4wd suburban. The mechanic suggested the same motor he had in his daily driver, which was a gm crate motor meant for the 93 caprice cop cars. All the mechanic could tell me other than that was that it was a 350 roller motor. I've got 35" tires and weigh ALOT! and only 3.73 gears, but this new motor has impressed me. I have searched and searched, and then searched a little more to the point of complete frustration to find any specs on this motor. Lots of people online are talking about it but nobody is telling any of the juicy stuff. I've gathered that its an L05, but thats about the extent of it. Anybody know what cam, info on heads, how many horseys, Torque, etc.? ANYTHING AT ALL!!!?
:hail: :hail: much appreciation for any info.:hail: :hail:
Old Feb 23, 2004 | 09:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I don't know what "juicy stuff" there is to tell....
Should do about the same as any other TBI 350, or around 210 HP. In other words, it's basically identical to what you have (had) in that truck, except that the factory's roller Frankenstein is installed in it. AFAIK they didn't change the cam profile when they rollerized it.
I certainly wouldn't spend that much money to get that. But that's just me.
Old Feb 24, 2004 | 04:47 AM
IROZINCO's Avatar
Caprice motor
This is the engine and specs. I was looking into getting it for my IROC - it's basically a drop-in replacement for the 350 in my 1987, once you factor in drivetrain loss, it's about the same HP/Torque numbers:
I'd post the web-link - but I think that is against forum rules
NEW 350 CID ENGINE CAST IRON HEADS, 1-PIECE REAR SEAL,1987+ INTAKE FACE, TUNE PORT ROLLER CAM
ENGINE FEATURES:
100% New engine, 350 CID, 2-bolt mains, V-8, 1-piece rear main seal, nodular iron crank, forged rods, 9.2:1 cast pistons, roller hydraulic cam, 1.94" intake valve, 1.50" exhaust valve, oil pump, oil pan, RH dip stick, valve covers, timing chain cover and harmonic balancer.
*Optional 2 Year or 24,000 mile parts and labor warranty is available for purchase.
NOTES: This engine is based on a 1993 motor with a roller hydraulic cam added. This cam works best with TPI 1987-89. Fuel injection may need additional fuel. A carburetor will require an electric fuel pump. 1987 and newer style intake manifolds and flywheels are needed with this engine.
CAM SPEC'S FOR ROLLER ENGINE
Duration @ .050" Lift Lobe
Int. Exh. Int. Exh. Centerline
214 220 .452" .465" 112
Old Feb 24, 2004 | 09:35 AM
TurboSteve's Avatar
Car: 1987 Formula
Engine: 383
Check this link out:
http://www.paceparts.com/product.asp...&1=360&3=23285
Old Feb 26, 2004 | 11:10 PM
Thank you TurboSteve, that was exactly the info i was hunting for. I should have just asked a long time ago. I only have one more question... on the page which that link takes you to at the top of the list of specs it says in yellow writing, "92-93B, D (LO5) (EXC 9C1) VIN CODE 7". To me that sounds like it is for the standard caprice and my motor is supposed to be for the cop car (9c1). Is that right?
Old Feb 27, 2004 | 09:19 AM
TurboSteve's Avatar
Car: 1987 Formula
Engine: 383
You've got me on that one. I would think it's the same engine, maybe with a different camshaft. I don't know for sure.
Old Feb 27, 2004 | 01:22 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
GM does not make a create engine for the 9C1, cop edition. The only caprice create engine they make is the one TurboSteve posted. I have the same engine in my car, just changed the heads and cam.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
Mickeyruder
Sep 2, 2015 02:45 PM
