what is the milling specs for the rocker stud bosses?
Old Feb 10, 2001 | 10:37 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I'm having my vortec heads drilled and tapped for screw in studs and guide plates. The machine shop that I always use needs to know how much to mill the bosses down to before they are tapped. They are very reputable and have done this same thing on other heads. I can't figure out why they are asking this. I told them I would find out and would get back to them on Monday. Are the bosses a different height on the vortecs?
Old Feb 11, 2001 | 12:02 PM
ede's Avatar
ede
if they don't know i think i'd be looking for another shop. you should be able to measure one of the studs you pulled aginst a screw in stud and figure it out. i've never done vortecs but on all the heads i have done i take .4 off if i'm using guide plates and .425 or .45 if i'm not.
ICON Motorsports
1st & 3rd
Old Feb 11, 2001 | 04:06 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
<font face="Verdana, Arial" size="2">Originally posted by ede:
[/B]</font>
That is what I was thinking, too. Thanks.
Old Feb 11, 2001 | 04:17 PM
Vader's Avatar
94,
The radius and hex collar on Mr. Gasket and ARP studs (hex-type) is about 0.375" under the thread. GMPP studs (P/N 12371058) are 0.325" to the shoulder. Add to that the thickness of the guide, plates, and you should have the depth measurement.
If your studs are different, measure the height under the thread to the mounting surface, and go from there.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 11, 2001 | 04:21 PM
355 IROC-Z's Avatar
even if you are not using guide plates, i would mill them down enough for them and put washers of approx. thickness of a guide plate under the stud. you never know when you might want guide plates.
yeah, if the machine shop didn't know how much in the first place, i would definately go somewhere else. milling down isn't precision science here, it is more commmon sense then anything.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
